Další klony tentokrát přijímačů.
[ 36.77 KiB | Zobrazeno 2988 krát ]
https://www.aliexpress.com/item/1005001 ... 4c4dYAg4TNR1mini D8
Number of channels: 8 channels
Frequency range: 2400-2483.5Mhz
Power supply range: 4.5-6V
Signal format: D8
Output format: sBUS
Support return: support return RSSI
Control distance: more than 1km
Antenna length: about 6 cm.
Weight: 2 grams
R161 D16
Product Features
Number of channels: 16 channels
Signal format: D16
Output format: sBUS
Support return: support flight control TELEMETRY. RSSI output
Out of control protection: CUSTOM /HOLD /NO PULSES
Antenna length: about 15 cm
Inch: 26*21*8.5 mm.
Quantity: 7g
R168 D16
Product Features
Frequency range: 2400 2483.5Mhz
Signal format: D16
Output phase type: PWM. SBUS
Support return: support "Flight control TELEMETRY. RSSI output, VBAT (up to 18V voltage detection)
Antenna length: about 15cm
Weight: 10g
