eds píše:Steve uvažuje o ukončení výroby P32 ??? Díky za informace.
Nie. O unifikácii náhonu satelitov prostredníctvom hriadeľu motora s ozubením (tak ako je u motorov 15xx).
We will still use the gear box -- we are moving away from offering separate pinion gears. Picture shows what the gear looks like when it is formed on the shaft vs a separate pinion. The formed version runs truer with less noise -- and with the new 6mm version shaft the front bearing can now be replaced when needed.
http://www.rcgroups.com/forums/attachme ... id=3215662
Q: if I wanted to convert one of my 11xx series motors over to gearbox (sometime in the future) that I could send it in and get a new shaft (or rotor?)?
A: that motor uses the 1.25 shaft pinion and we will still have those.
