kabel k telemetrii alternativa UNISENS-E
ahoj, viete mi odporučiť nejaku alternatívu usb k telemetrii s tymto konektorom ? Výrobca udáva kompatibilitu s Jeti, Multiplex a Graupner ale pozicany multiplex nie je kopmpatibilny, dik
Re: kabel k telemetrii alternativa UNISENS-E
do toho konektora ide len ten ich " SM-Modelbau-USB Interface No 2550 " a kabel pre pripojenie displeja. Ten ma na konci kabla konektor ktory pasuje do toho na Unisens-e. Mohlo by to fungovat aj s nejakym prevodnikom USB/TTL ( GND, RX,TX, ? ). Neskusal som. Ak mas Jeti USB kabel ( alebo Multiplex, Graupner ), tak ten sa pripaja na LINK konektor ( tam kde ide kabel pre telemetriu z prijimaca ). V manuali je aj postup ( poradie ) pripajania k PC.
Currently the following cables have been tested:
SM-Modelbau-USB Interface No 2550 ➔ > is directly connected to the COM port of
the UniSens-E.
> No further adapters needed.
> First plug in the cables then click “connect”
in the software
Jeti Duplex "USBa" USB adapter ➔ > connected to the LINK port of UniSens-E.
> First click “connect” in the software then
connect the Jeti cable to the UniSens-E
Multiplex "USB PC cable" # 85149 ➔ > connected to the LINK port of UniSens-E.
> V cable with Rx battery for power required.
> First connect the V cable to the MPX cable
and the receiver battery plug.
> Then click “connect” in the software and
immediately after connect the UniSens-E
to the V cable.
Graupner "USB interface" No. 7168.6 ➔ > connected to the LINK port of UniSens-E.
> adapter cable 7168.S required.
connect the 7168.S adaptor cable to the
UniSens-E
EDIT: Mozno je na tom konektore ( GND,+,RX,TX) alebo (GDN,+,TX,RX) a napajanie cez LINK konektor. Takto to vie napajat displej a komunikovat s nim.
the UniSens-E.
in the software
to the V cable.
UniSens-E
Dakujem za odpoved, ked som to prehliadol a videl som usb na jeti, rovnako mi napadla moznost skusit pouzit LINK konektor, ale nakolko ho nemam a budem musiet nieco zohnat, radsej som to pred tym vyvesil sem, nech si to potvrdim, alebo aspon zozbieram nejake postrehy, ak uz to niekto riesil, este raz dik
