TTSAutomate
Caffeine
TTSAutomate
#1 Příspěvek od Caffeine »
Added SSML support to TTSAutomate.
Examples:
  • Break / pause for a specified time (Ivona appears to be buggy, breaks > 10 seconds are clipped to 10 seconds, but you can chain multiple breaks together, i.e. <break time="10s"/><break time="10s"/><break time="3s"/> = 23 seconds)
Kód: Vybrat vše
Here is a <break time="3s"/> 3 second gap
  • Adjust pitch (appears to be not supported with the Microsoft TTS engines)
Kód: Vybrat vše
<prosody pitch="+95%"> Try high pitch</prosody> <prosody pitch="-95%"> or low pitch</prosody>
  • Adjust speech rate
Kód: Vybrat vše
The following word will be spoken <prosody rate="-50%">slowly</prosody>
  • Adjust volume
Kód: Vybrat vše
The following word will be spoken <prosody volume="20">quietly</prosody>
Available here:
https://github.com/CaffeineAU/TTSAutomate/releases/tag/2.6.0.0
Naposledy upravil(a) Caffeine dne pon 19.09.2016 14:20, celkem upraveno 1 x.
Caffeine
TTSAutomate Release 2.7.0.1
#2 Příspěvek od Caffeine »
  • Add support for opening phrase files in a different encoding
The following encodings are supported:
  • UTF-7
  • UTF-8
  • UTF-16LE (Unicode)
  • UTF-16BE (Big Endian Unicode)
  • UTF-32
  • ASCII
The options for opening the phrase files have been roughly translated using Google Translate.
https://github.com/CaffeineAU/TTSAutomate/releases/tag/2.7.0.1
TTSAutomate 2.7.0.1.png (6.62 KiB) Zobrazeno 3328 x
Caffeine
TTSAutomate 2.7.1.0
#3 Příspěvek od Caffeine »
Add option to limit filename length (highlight existing filenames that exceed the specified length, and also prevent editing filenames to be greater than the specified length)
https://github.com/CaffeineAU/TTSAutomate/releases/tag/2.7.1.0
rehurek
Re: TTSAutomate
#4 Příspěvek od rehurek »
Tak opět máme k dispozici novou verzi 2.8.0.1
https://github.com/CaffeineAU/TTSAutomate/releases/tag/2.8.0.1
Nyní má instalátor a je asociován s PSV soubory. Nyní dvojklikem otevřete PSV soubory v TTSAutomate.
Je přidána i verze Portable
FrSky Taranis E
MIG29, AlphaJet, SE5A, FW-190, DJI F450 s NAZAv2 a HERO3+, X525 s MM2.0
Caffeine
TTSAutomate 2.8.2.1
#5 Příspěvek od Caffeine »
  • Update French translation
  • Fix Ivona handling of accented characters
  • Restored installed version
  • Other secret stuff that doesn't do much yet ;-)
https://github.com/CaffeineAU/TTSAutoma ... ag/2.8.2.1
Caffeine
Re: TTSAutomate
#6 Příspěvek od Caffeine »
Please be aware that the Ivona voices are currently disabled as we have used up our monthly quota of voices.
The Ivona voices will be available again on April 1st.
In the longer term, Ivona will be deprecated and we will be forces to change to Amazon Polly, which has similar features, but will only allow free use in the same scale as Ivona for 12 months. After that, the service will be pay-to-play
Caffeine
Re: TTSAutomate
#7 Příspěvek od Caffeine »
TTSAutomate 3.0.0.0 is released.
I had hoped to include full voice editing functionality in the 3.0.0.0 release, however Ivona forced my hand by turning off their TTS service. Hence I have done an initial integration of Amazon Polly.
I'll monitor the usage of Polly and if it exceeds the free tier, I may disable it.
Get the new version here:
https://github.com/CaffeineAU/TTSAutomate/releases/tag/3.0.0.0
Caffeine
Re: TTSAutomate
#8 Příspěvek od Caffeine »
As the 12 month free tier for Amazon Polly will be expiring in a couple of days, I've created a website to host TTSAutomate updates from now on.
TTSAutomate is still free to download and use, however I've added an no obligation option to purchase 'support' through PayPal in case anyone would like to contribute to the costs of running it.
I'm still working on the website. I hope to have a lot more content there shortly about how to use TTSAutomate, with plenty of example PSV files, plus links to OpenTX, er9x and any other projects that may benefit from the voices that TTSAutomate can produce.
The website is live at https://www.ttsautomate.com/
