Používám 6s lipo baterie a motory Foxtech w4822 - 390KV ( fxtech už jej na webu nemá, tak aspoň stejný motor s jinou nalepkou http://www.goodluckbuy.com/hengli-w4822 ... 4n22p.html )
a ta nová verze je Foxtech s4810 - 390KV ( http://www.foxtechfpv.com/foxtech-motor ... -1683.html )
Dle komunikace s eshopem -
| 28.08.2014 13:53:18 | Doris: s4014 kv390 is no problem to work with the old w4822 kv390
| 28.08.2014 13:53:41 | Doris: so it's ok to buy only one s4010 kv390
| 28.08.2014 13:53:58 | Dusan Chlud: You sure about that?
| 28.08.2014 13:55:15 | Doris: yes sir
| 28.08.2014 13:55:27 | Doris: they are no problem to work on the same copter
| 28.08.2014 13:56:31 | Dusan Chlud: OK than.. that could fix my problem.. thank you Doris
Mám jim věřit a objednat jen jeden motor nový nebo radíte jinou cestu, jak to řešit?
