téma: křidélka - FY20A
ještě o tom psal Houmr tady
http://www.rcmania.cz/viewtopic.php?f=39&t=40600&start=40 a tady
http://www.rcmania.cz/viewtopic.php?f=39&t=40600&start=44Píše tam, že má jedno křidélko přes FY-20A a jedno napřímo od přijímače, aby mohl využívat diferenciaci.
v manuálu se píše:
Plane Connection Layout:
1) Normal / Traditional servo layout:
Servo 1 Servo 2 Servo 3
Aileron servo Elevator servo Rudder servo
2) Plane without aileron servo:
Rudder servo Elevator servo Don't connect
3) Delta-winged plane servo:
Differential servo 1 Differential servo 2 Rudder servo
The Rudder channel is not involved in any of the mixing done inside the FY20A. Therefore, you can:
1. Keep the FY20A rudder channel (RUD IN, RUD OUT) open (not used).
2. Connect Receiver channel 4 to FY20A (RUD IN) & connect the rudder servo to RUD OUT (as per traditional fixed wing layout).
Aileron-Elevator MixingDE-ACTIVATE MIXING IN YOUR RADIO IMPORTANT: If you have differential mixing already set in your radio, please deactivate it. The FY20A will take over the mixing function. Your radio setting should be the traditional plane settings.
For Delta Wing with Elevator signal mixing (e.g. Flying wing Elevon) - differential output is carried out by using the supplied jumper as shown on the right:- The jumper has to be installed before powering ON. If you install it after powering ON, the mixing function will not take effect.
Do not remove this jumper.
Leave it installed as long as you are using the mixing function.
SPEKTRUM DX6i | HD Contour GPS | ZagiKiller 1500, HotWing 1200 (+1800), Alpha 1500, SkyClimber 2000
