Popis obou možných nastavení pro chování motorů u NAZA jednotky :Wormsnake píše:... Kdyz s nazou pristanu a stahnu uplne plyn naza za 3 vteriny vypne motory to je me jasny.
Ale co udela naza jednotka kdyz z velmi vysoke vysky budu prudce klesat s plynouvou pakou stahnutou uplne dolu dele nez 3 vteriny?...Vypnou se motory i vzduchu? Nebo to jednotka jednotka nejak hlida, a muzu si to vrcet dolu a bez starosti ze kdyz budu chtit reakci na plyn budou matory vypnute?
Immediately
In any control mode, once motors start and throttle stick is over 10%, motors will stop immediately when throttle stick is back under 10% again.In this case, if you push the throttle stick over 10% within 5 seconds after motors stop, motors will re-start. If you don’t push throttle stick after motors start in 3 seconds, motors will stop automatically.
Intelligent (nejčastěji používané nastavení)
In any control mode, only push both sticks to the left or right bottom can stop motors.In ATTI./GPS Mode, any one of following cases will stop motors.
(1)You don’t push throttle stick after motors start within 3 seconds.
(2)Throttle stick under 10%, and after landing 3 seconds.
(3)The slope angle of multi-rotor is over 70°, and throttle stick under 10%.
