TBS Discovery a jeho klony
stanikg
#901 Příspěvek od stanikg »
zdravim vas ide zima a chcel by som si urobit klon tbs ale som vtakych stavbach zaciatocnik tak by som vas poprosil o posudenie dielov . stavbu by som chcel urobit co najlacnejsiu tak akurat mojim pomerom ale jednoduchu aby som to zvladol sam poskladat .
vysielacku mam dx6i dsmx
posudenie dielov ci by to mohlo fungovat ked nie tak ma opravte alebo skuste my poradit nejaky setup ktory funguje .gymbal chcem zatial mobius ma tuto kamerku tak pre zaciatok ju vyuzijem.
ram 1http://www.dx.com/p/hj-x-mode-mwc-alien-multicopter-quadcopter-frame-kit-for-r-c-helicopter-white-black-193525#.VGsXQZ-zlks
ram 2http://www.hobbyking.com/hobbyking/store/__56213__HobbyKing_Super_H_600_QuadCopter_KIT_.html
motory http://www.hobbyking.com/hobbyking/store/__36767__Turnigy_Multistar_3525_850Kv_14Pole_Multi_Rotor_Outrunner.html
Rj http://www.hobbyking.com/hobbyking/store/__51632__DJI_Naza_M_Lite_Multi_Rotor_Flight_Controller_GPS_Combo.html
esc http://www.hobbyking.com/hobbyking/store/__39708__Afro_ESC_30Amp_Multi_rotor_Motor_Speed_Controller_SimonK_Firmware_.html
gimbal http://www.hobbyking.com/hobbyking/store/__55689__Turnigy_Mobius_2_Axis_Gimbal_with_Tarot_Controller_and_AX2206_Motors.html
fpvhttp://www.hobbyking.com/hobbyking/store/__66474__Skyzone_Plug_N_Play_FPV_500_Set_With_TS58500_TX_RC832_RX_Sony_700CCD_and_C_P_Antennas.html
vrtule http://www.hobbyking.com/hobbyking/store/__45036__9x4_7E_Multistar_Carbon_Fiber_Propellers_CW_and_CCW_Rotation_with_DJI_Fitting_1_pair_.html
prijmac http://www.hobbyking.com/hobbyking/store/__38392__OrangeRx_R800X_DSMX_Compatible_8Ch_2_4Ghz_TwinPort_Rx_.html
doska bec http://www.hobbyking.com/hobbyking/store/__55556__Quanum_Power_Distribution_Board_and_Dual_UBEC_In_One.html
VBar Control , Logo 550 SX+Neo, Goblin700 Competition+neo , Icharger 4010duo ,
jamesgsf
#902 Příspěvek od jamesgsf »
Petře na jakém pásmu jedeš video? Pokud na 5,8 tak by tam žádné ruchy neměly být, zvláš't když jedeš z baterky solo. A nemyslím si že by byly nutné LC filtry, jinak nejednoduší je vyzkoušet toto http://rcmania.cz/viewtopic.php?f=96&t=42332 Já jsem s ruchy v copteře neměl problém žádný problém, jedu taky 4S a vše v pohodě, spíše není stabilizátor jako stabilizátor a ten je většinou zdroj problémů do videa. Ten jednoduchej LC filtr mne pomohl dost v letadle, jen by to chtělo asi větší s kondenzátor a byl bych uplně bez ruchů (pruhů) ještě je v letadle mám trošičku vidět.
sorry psal jsem to z telefonu
Naposledy upravil(a) jamesgsf dne úte 18.11.2014 21:34, celkem upraveno 1 x.
PetrVIVIVI
#903 Příspěvek od PetrVIVIVI »
stanikg píše:zdravim vas ide zima a chcel by som si urobit klon tbs ale som vtakych stavbach zaciatocnik tak by som vas poprosil o posudenie dielov . stavbu by som chcel urobit co najlacnejsiu tak akurat mojim pomerom ale jednoduchu aby som to zvladol sam poskladat .
Rám mam doma ten alien x tak se mužem domluvit jestli chceš. Je to dobrý rám. Motory vem raději Sunnysky stojí zhruba stejně a jsou prakticky bez vibrací. Afro a naza ok.
Phantom 4 / DJI Inspire 1 PRO / Phantom 3P
PetrVIVIVI
#904 Příspěvek od PetrVIVIVI »
jamesgsf píše:Petře na jakém pásmu jedeš video? Pokud na 5,8 tak by tam žádné ruchy neměly být, zvláš't když jedeš z baterky solo. A nemyslím si že by byly nutné LC filtry, jinak nejednoduší je vyzkoušet toto http://rcmania.cz/viewtopic.php?f=96&t=42332 Já jsem s ruchy v copteře neměl problém žádný problém, jedu taky 4S a vše v pohodě, spíše není stabilizátor jako stabilizátor a ten je většinou zdroj problémů do videa. Ten jednoduchej LC filtr mne pomohl dost v letadle, jen by to chtělo asi větší s kondenzátor a byl bych uplně bez ruchů (pruhů) ještě je v letadle mám trošičku vidět.
Zkusím jeste dat zvlášť baterky na monitor a přijímač protože to mam dohromady.
stanikg
#905 Příspěvek od stanikg »
Super a ktory motor sunnysky je vhodny na ten tvoj ram .trosku tapem nad motormy
PetrVIVIVI
#906 Příspěvek od PetrVIVIVI »
stanikg píše:Super a ktory motor sunnysky je vhodny na ten tvoj ram .trosku tapem nad motormy
Mam to v popisu x2212-13 třeba z banggood nebo ebay.
xnokiax
#907 Příspěvek od xnokiax »
PetrVIVIVI píše:
ahoj
mam tie motory. vsetko ok. ale mam otazku. raz mi koptera padla ked sa este tocili vrtule a tie matky sa mi povolili a vypadli to travy- ledva som ich nasiel aj s podlozkami. na motore 1 a 3 lebo tie sa tocia opacne. ako to mas vyriesene alebo co sa s tym robi? tie moje motory maju vsetky rovnaky zavit- myslim smer zavitu. na niektorych motorch byvaju zavity na 2 motoroch opacne.
vdaka
total amater :(
PetrVIVIVI
#908 Příspěvek od PetrVIVIVI »
Tak buď matky s brzdou nebo jak se to jmenuje nebo použit threatlocker.
ST
#909 Příspěvek od ST »
Přikládám jeden záznam z letu s Discovery s vyváženými vrtulemi. GoPro 3+ BLACK je na rámu bez žádných odpružujících bazmeků. Doprčic já už chci nějaký gymbál co by se dal na Discovery legálně namontovat. :(
[youtube]http://www.youtube.com/watch?v=w5tH8uqrU_A[/youtube]
jamesgsf
#910 Příspěvek od jamesgsf »
A to je nelegální si tam dat gimbal?
jamesgsf
#911 Příspěvek od jamesgsf »
A to je nelegální si dat gimbal na copter?
ST
#912 Příspěvek od ST »
Není, ale pořád nevím jaký zvolit, aby to šlo trochu sofistikovaně namontovat na rám discovery.
jamesgsf
#913 Příspěvek od jamesgsf »
Tak ne legálně ale ideálně :-) no na ty tbsce to je trochu problém.
ST
#914 Příspěvek od ST »
Jo pořád si to kalkuluju, jestli utopit peníze v nějakém bastlu a nebo koupit zrovna Discovery PRO. Zatím jsem v situaci, že teda fakt nevím . :lol:
jamesgsf
#915 Příspěvek od jamesgsf »
Nebo změnit platformu quadry. Neboj ale nejsi v tom sam já s tím taky bojují už víc jak rok i proto jsem opustil tento concept a přešel na Qav tam je ke všemu aspoň lepší přístup ale jello se mne nedaří potlačit tak jak bych si představoval.
Zpět na „Coptery - projekty“
