HGLRC F4 flame
Fofan
HGLRC F4 flame
#1 Příspěvek od Fofan »
Cau. Predem upozornuji ze krome toho ze litam s blechou qx95, tak jsem porad zacatecnik s minimem znalosti, prosim budte ke me schovivavi[emoji1] Hledam neco ohledne me fc ale uz sem bezradnej, tak snad nevadi ze zakladam tohle novy vlakno. Postavil sem svoji prvni copteru a ted resim uz jen nastaveni a zprovozneni prez bf. Muj setup vypada nasledovne:
Ram: REPTILE Martian II 2 220 / 250 220mm 250mm 4mm Arm Thickness Carbon Fiber Frame Kit w/ PDB For FPV Racing
http://s.aliexpress.com/BnA7JFRz?fromSns=Copy to Clipboard
Ridici jednotka HLRC f4 flame s integrovanym pdb: docela dobry info k teto desce https://www.propwashed.com/hglrc-f4-flame-review/
Receiver: Flysky 2.4G 6CH FS-iA6B Receiver PPM Output With iBus Port
https://banggood.app.link/BcsqdKrWuN
Motory: Racerstar Racing Edition 2306 BR2306S 2400KV 2-4S Brushless Motor For X210 X220 250 RC Drone FPV Racing
https://banggood.app.link/zN975iPVuN
Regulatory: Racerstar RS30A V2 30A Blheli_S ESC OPTO 2-4S Support Oneshot42 Multishot 16.5 Dshot600
https://banggood.app.link/k3q3NQZSuN
Vrtule: 10 Pairs KINGKONG/LDARC 5040 5x4x3 3-Blade Single Color CW CCW Propellers For FPV Racer RC Multicopter Spare Parts
http://s.aliexpress.com/qY7niUrI?fromSns=Copy to Clipboard
Video vysilac: Eachine TX526 5.8G 40CH 25MW/200MW/600MW Switchable AV Wireless FPV Transmitter RP-SMA Female
https://banggood.app.link/6BCcNRXVuN
Video antena: dys 5.8 Mushroom https://goo.gl/images/WU38Mv
Baterie: zatim na zkousku zippy 1300mAh 25c
Radio: flysky fs-th9x s modulem AFHDS A2, software openTx
Bryle: Eachine ev100
Jde mi nejprve o zapojeni prijimace do desky a oziveni coptery, prikladam obrazek se schematem. Jelikoz mam flysky prijimac tak jedu prez ppm, zapojil sem to lajcky dle obrazku na ppm signal, ale zatim nerozumim nastavrnim portu. Na tomhle obrazku uz dotycny dokreslil uarty, nemam to tedy blbe? Opravdu to delam poprve a potrebuji takovej ten zaklad, hodilo by se mi kdyby to se mnou nekdo probral bod po bodu podle myho setupu a polozku po polozce v betaflight, ale prekpokladam ze me nikdo za rucicku takhle vodit nebude [emoji1]
imagin
Re: HGLRC F4 flame
#2 Příspěvek od imagin »
ja tam číslo UART pro přijímač nemůžu vyčíst, ale to je jedno. V nastavení zvolíš PPM a v portech pak Tvůj UART. (více na obrázcích - ale musíš samozřejmě SVŮJ UART, toto je jen ukázka kde se to dělá)
Když UART nevíš zkoušej, taky to lze :)
iF
FPVMANIA - MOTHER COPTER - FLY or DiE
Oficiální distributor Armattan Quads pro ČR
fpvmania.cz
Fofan
Re: HGLRC F4 flame
#3 Příspěvek od Fofan »
Jak pises tak sem to zkusil, zadal sem ppm a pak sem zkousel uart 1,3,6 ale nic, ja mam ale servokonektor od prijimace napajenej na tom gnd a ppm na obrazku nahore a nevim jestli treba signal nema byt z jednoho z tech TX/RX co sou oznaceny na obrazku. Diky za pomoc [emoji106]
tomas1987
Re: HGLRC F4 flame
#4 Příspěvek od tomas1987 »
vypln si bydliště, třeba se někdo z okolí ozve
Fofan
Re: HGLRC F4 flame
#5 Příspěvek od Fofan »
Vyplnim diky[emoji106] zapojil sem to takhle, ale jeste jsou tam uarty pod nazvama tx/rx ktery nemam obsazeny, mam to dobre?
Jak vložit fotku z tapatalku: /20180606/cd6a7eccaeed9e4df347bcea2928471a.jpg[/img]Jak vložit fotku z tapatalku: /20180606/8c30e9a41eb6df94b5d25b95185fb473.jpg[/img]
Sorry ale najednou me to nezobrazuje fotky, snad to vidite.
Fofan
Re: HGLRC F4 flame
#6 Příspěvek od Fofan »
Tak sem prijimac zapojil na desce do sbus a na prijimaci do ibus a v betaflightu v configuration nastavil sbus a v podmenu ibus a stale nic. Vubec neodarmuju, prijimac je sparovanej
Edit: navic me betaflight ukazuje obsazeny jen 3 prvni kanaly, flashnul sem desku na omnibusf4 verze 3.3.3. stabilni
Fofan
Re: HGLRC F4 flame
#7 Příspěvek od Fofan »
Tak hotovo vyreseno! V podstate sem na prijimac zapojil ibus a signal napajel z rx1, nastavil v betaflight uart a receiver pres sbus a pak podmenu ibus. Je to fakt masakr kdyz to vzleti, ten prvni pocit je nepopsatelnej [emoji1] asi jako kdyz prestoupite z trabanta do ferrari
Mam trosku problem s jednim motorem, je vetsi vule na lozisku a kdyz si ho roztocim pomale na stole tak v nem docela klepe, ale za letu to nijak nepoznam, fixnu ty osy a zkusim s tim normalne litat.
