Odeslat nové téma Odpovědět na téma  [ Příspěvků: 3 ]
 Předmět příspěvku: Stabilizácia - inštalácia
PříspěvekNapsal: úte 29.09.2020 17:10
Obrázky: 48
Ahoj.
Na lindigeri som kúpil QQ Extru od Quique Somenzini a teraz sa snažím rozbehať stabilizačný systém Aura 8.
Keď si stiahnem oficiálny soft pre počítač /uprostred strany step 1/:
http://wiki.flexinnovations.com/wiki/Au ... oolInstall
tak sa nedá otvoriť a nainštalovať, skúšal som aj vypnúť firewall, aj otvoriť ako správca ale neide to , tam som skončil. Viac s tým nepohnem.
počítač: Windows 10pro, 64bit.
Vie niekto pomôcť?
[ 506.17 KiB | Zobrazeno 1227 krát ]
kompletný log chyby:
The following properties have been set:
Property: [AdminUser] = true {boolean}
Property: [InstallMode] = HomeSite {string}
Property: [NTProductType] = 1 {int}
Property: [ProcessorArchitecture] = AMD64 {string}
Property: [VersionNT] = 6.3.0 {version}
Running checks for package 'Microsoft .NET Framework 4 (x86 and x64)', phase BuildList
Reading value 'Version' of registry key 'HKLM\Software\Microsoft\NET Framework Setup\NDP\v4\Full'
Read string value '4.8.03752'
Setting value '4.8.03752 {string}' for property 'DotNet40Full_TargetVersion'
The following properties have been set for package 'Microsoft .NET Framework 4 (x86 and x64)':
Property: [DotNet40Full_TargetVersion] = 4.8.03752 {string}
Running checks for command 'DotNetFX40\dotNetFx40_Full_x86_x64.exe'
Result of running operator 'ValueEqualTo' on property 'InstallMode' and value 'HomeSite': true
Result of checks for command 'DotNetFX40\dotNetFx40_Full_x86_x64.exe' is 'Bypass'
Running checks for command 'DotNetFX40\dotNetFx40_Full_setup.exe'
Result of running operator 'ValueNotEqualTo' on property 'InstallMode' and value 'HomeSite': false
Result of running operator 'VersionGreaterThanOrEqualTo' on property 'DotNet40Full_TargetVersion' and value '4.0.30129': true
Result of checks for command 'DotNetFX40\dotNetFx40_Full_setup.exe' is 'Bypass'
'Microsoft .NET Framework 4 (x86 and x64)' RunCheck result: No Install Needed
Launching Application.
URLDownloadToCacheFile failed with HRESULT '-2146697213'
Error: An error occurred trying to download 'http://dev.flexinnovations.com/configTool/AuraConfigTool.application'.
 Předmět příspěvku: Re: Stabilizácia - inštalácia
PříspěvekNapsal: stř 30.09.2020 8:05
Stručně:
mě se "auratool" nainstalovat podařilo. Viděl bych to na malá práva na instalaci.
Podrobněji:
Aplikace se instaluje do šuplíku uživatele* + chce instalovat nějaké ovladače. Instalace "do šuplíku uživatele" je asi relativně OK (nemusí musí být power user?), na instalaci ovladačů chce určitě admin práva.
Program je z roku 2018, takže nic starého, nainstalovat by měl jít.
* takové to, jak je program na webu a instalátor se podívá jestli má uživatel aktuální a stáhne mu program do jeho složky... teď nevím, jak se to jmenuje. Tyhle programy nemohou běžet v Admin modu.
(šroubovák | kleště | měřák | pájka | drátky | poletuchy | 24ch volantovka | 8ch FlySky FS-T6)
PříspěvekNapsal: čtv 01.10.2020 11:08
Obrázky: 48
Na inom počítači to ide takže je problém v domácom PC, zatiaľ som sa utopil v začiatku návodu.
Kam na SD karte vysielačky mám nahrať FrSky Transmitter Model File?
Uživatelé procházející toto fórum: JirkaA a 9 návštevníků
