Joo tak to je cool
... Musel ještě upravit FW jelikož s telefonem je akční rádius omezen na 100m
!!! To bude šikula
Btv včera byla propuštěná nová verze FW pro Sparka i jeho RC. Zde je seznam změn:
-Improved photo resolution to 4K in Gesture and ActiveTrack modes.
-Added a new gesture for video recording.
-Added an option to adjust gimbal tilt sensitivity.
-Added a 180° Pano shooting mode.
-The aircraft will descend to a height of 1.5 m while flying below 4.5 m or descend 3 m while flying above 4.5 m if no subject is detected for more than one minute in Gesture
mode.
-Improved overall gesture recognition and reduced the probability of falsely recognizing the selfie gesture. The wave gesture is now disabled by default while flying indoors or
where the GPS signal is weak to ensure safety. The wave gesture can be enabled in both situations by adjusting settings in DJI GO 4.
-Fixed an issue where photos failed to save and the shutter sound would not be made while taking photos in Gesture mode.
-The aircraft will now exit QuickShot automatically when a control stick is pulled opposite to the direction of flight. Flight distances for QuickShots can now be set in DJI GO 4,-
with greater maximum flight distances while using the remote controller. Also, flight directions for Circle and Helix can now be adjusted in DJI GO 4.
-Fixed an issue where the aircraft didn’t ascend high enough with the Dronie QuickShot and optimized Rocket.
-Optimized the FPV gimbal mode in Sport mode to keep the gimbal from reaching its endpoint.
-Fixed issue where the remote controller would occasionally disconnect from the aircraft.
-Fixed a rare issue where the remote controller couldn’t be turned off.
-Improved aircraft and remote controller responsiveness.
-Optimized battery level calculation.
Včera jsem dal s tímto FW pět letů a vše se zdá v pořádku. Bohužel jsem nemohl otestovat nové funkce protože jsem neměl poslední GO4 v 4.1.4... Trochu jsem aktualizací zklamán, protože nebyl vyřešen problém s WiFi v EU... Trochu se začínám obávat že wifi modul ve Sparku nepodporuje evropskou kanálovou tabulku už na HW úrovni
, pak samozřejmě nemají šanci s tím cokoliv udělat pomocí aktualizace FW.. No necháme se překvapit..
